I read a lot of you are using the 75-90 weight synth rear Amsoil fluid, my question before I do this is…what is the stock gm weight? 80-90? If so why not use the 80-90 synth Amsoil?
The stock spec was synthetic 75w90.
AMSOIL's best gear lube doesn't come in a 80w90, only 75w90. Been using this at the track for about 10 years now and haven't lost a diff yet (though I have rebuilt it a few times and finally replaced it last year after 10 years of racing): AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
Note: This fluid comes with friction modifier already in it and extra additive isn't normally needed in the C5 to prevent diff chatter.
I ordered 3qts of it yesterday along with torque drive and an oil filter so I'll put it all in and hope it works as well as I keep hearing ^_^
you only need 2qts and you will have a small amount left over... guess your next diff fluid change will be 1/2 price... I've used amsoil fluids in the trans and diff since I've owned my car and it has been great
I just added severe gear in the rear without the additive and haven't had any issues. The torque drive atf in the transmission was a relevation. Shifts are smooth with no balking. I just today installed a C6 shifter, taking the shifting to the next level!
no additive needed, as stated above the fluid has its own addidive... I've changed mine a few times over 4 years with strictly amsoil gear oil (no extra additive) and haven't had any issues
Well that's a waste of $15 I guess on my end :/ also I heard I wouldn't need the additive? Now I do? I didn't buy any should I pick some up?
As mentioned above, the Severe Gear 75w90 comes with additive in it. The vast majority of C5/C5 Z06 diff's do not need extra additive to prevent diff chatter.
Note that isn't the case for the C6/C6 Z06 which do require a lot more additive than the C5/C5 Z06 diff as GM increased the diff plate pressure on the C6. For C6 owner's I do recommend more additive than is in the Severe Gear. And yes, the C6 Z06 diff does require 3 qts but the C5 Z06 will come in at about 1.6 qts or so.
I just changed my oil, trans and rear fluid yesterday, the rear of my 03 Z ended up taking 1.9-2qts I waited till the fluid started to run out of the fill and it happened right as we pumped the last bit of the 2nd quart in
Yep..>Severe Gear is way to go...been Amsoil dealer and using their products in everything from 3 Indian motorcycles, Land Cruisers (84, 2000, 2008), BMW 335i and now my Vette. Never a problem.....great product in spite of some naysayers.
Yep.....I use SG 75-110 in my 02Z and 03S2000.Great stuff.
