Bar upgrade 2001 base
Old Nov 4, 2014 | 08:16 PM
twettybyrd's Avatar
twettybyrd
Default Bar upgrade 2001 base
hi folks
i'm comfused here, should i buy c6z51bars or
c5z06bars kits from parts house
i believe both will work without modification
thx for your advice
Old Nov 4, 2014 | 08:33 PM
Smoken1's Avatar
Smoken1
I was told to use the c6z51bars for my 02 vert. Fit perfect
Old Nov 5, 2014 | 09:14 AM
wolf8218's Avatar
wolf8218
It'll probably be easier to just use C6 Z06 bars. I used both of mine on my C5 after getting upgrades on the C6 and I haven't had an issue.
Old Nov 5, 2014 | 09:58 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I put C6 Z51 bars on a '99 and C6 Z06 bars on another '99. They both will bolt up fine.
To me they both felt the same (they are the same front bar). I did not push the C6 Z06 bars enough to see if it had oversteer, but that is the concern with C6 Z06 bars.
The general recommendation is based on how big your rear tires are. If bigger than about 325 tires then go with the C6 Z06 bars and if smaller go with the C6 Z51 bars. The C6 Z06 bars with smaller (under 325) tires is said to cause oversteer.
The C6 sway bar upgrade (with metal end links) is a great performance mod. It really helped on mine.
To Bar upgrade 2001 base
