Wheel Speed Sensor Going Crazy
Old Nov 7, 2014 | 08:39 PM
2KMYCorvette's Avatar
2KMYCorvette
Default Wheel Speed Sensor Going Crazy
Hello everyone, I was wondering if anyone can point me in the right direction here.
I have a weird issue right now regarding the wheel speed sensors. All of them are throwing excessive wheel speed (no other codes are present) and causing my traction/abs system to act up and show lights. I have tried to clear the codes and it worked once or twice but now the codes are staying there.
I am wondering if maybe a bad ground is causing all of this? If anyone can tell me where the ground is for the wheel speed sensors?
I have also changed the stock rims to C5 Z06 rims about a month and a half ago and these codes never showed up until about a week ago.
Any insight on this would be appreciated.
Old Nov 9, 2014 | 10:36 AM
2KMYCorvette
Okay I will go ahead and check that, the car did go through a couple of high waters which probably got into the sensors. What I find weird is that when the code does not show, my steering is as smooth as butter but when the service traction/abs comes on my steering gets a little more stiff.
I do go down a very bad/bumpy road twice a week.... I am gonna see if not going down that road anymore will change things. I am really hoping its not the EBCM because $800 for a used one is crazy...
Old Nov 9, 2014 | 11:51 AM
martysauto's Avatar
martysauto
St. Jude Donor '14
Post all your codes c & h
To Wheel Speed Sensor Going Crazy
