Kooks Header install difficulty
Old Nov 18, 2014 | 12:25 PM
Pirateslife4me's Avatar
Pirateslife4me
Default Kooks Header install difficulty
Always heard great things about Kooks Headers but also read tons on nightmares with installation. Are the 1 3/4" as difficult to install as the 1 7/8"?
Also what are y'alls feeling on running cats or not. Im in Florida so no emissions testing here also car engine wise is stock at the moment except for Corsa extreme and Corsa xpipe
Old Nov 18, 2014 | 12:46 PM
jfernandez98's Avatar
jfernandez98
I can only comment on the new design. I installed the 2" new style and they went in easier than the old LG 1 3/4" . Kook's installed from the bottom with no clearance issues.
Old Nov 18, 2014 | 01:27 PM
aaronc7's Avatar
aaronc7
As the guy above eluded to... they redesigned their C5 header design sometime in 2013 IIRC. I have a set I bought earlier this year and it went in with zero drama, no clearances issues doing the install in my garage on jack stands. Worst part was removing the stock stuff. I have the 1 7/8" model.
Old Nov 18, 2014 | 03:33 PM
Pirateslife4me
Awesome… I don't have a lift and not into the jacking the motor up and removing everything under the sun to get these things in. I had heard about the re-design and and easier fitment but didnt know if that applied across the board to all their C5 LT headers or if it was a specific model header. Are y'all running cats or did you go without?
Old Nov 18, 2014 | 03:51 PM
ssrallyred's Avatar
ssrallyred
Same with me I installed my 17/8's by myself start to finish in about 5 hours. I removed the coil packs and plugs but nothing else(starter or alternator). This was my first set of headers on a Vette but have done probably all brands on a 4th gen Fbody and these were as smooth an install of any of those.
Old Nov 18, 2014 | 04:05 PM
aaronc7's Avatar
aaronc7
Originally I went with cats but now I have the catless x pipe on. I don't drive the car everyday so I don't mind the smell. Not a bad smell to me, but it is there-- not overwhelming or anything. If the car was my DD I would have kept the high flow cats on. Sound wise, catless is a bit louder but not hugely different on my stock Ti exhaust.
Old Nov 24, 2014 | 03:19 PM
Stroker87's Avatar
Stroker87
I just had a set of kooks 1 3/4 (old style) installed on my car I had LG street series on it that was trashed, i can tell you the LG's came out fairly simple in about any hour, the installer tried to get the kooks in from the bottom fiddled with them for about 2.5 hours until he finally gave it a shot from the top (witch is how the old pairs get installed) once he moved to the tops side they was installed in about 2 hour
had to remove the following:
plugs
wires
coil packs
alternator
steering shaft
temp plug from drivers side head
oil filter
oil sending unit housing
it took some finesse with jacking the engine and 4ft pry bar, I think if he would of pulled the valve covers it might have been a "little" better, the alternator bracket was left on and did make it a little harder
Old Nov 24, 2014 | 05:39 PM
XotiK ZO6's Avatar
XotiK ZO6
I installed them with a friend. It wasn't complicated.
Get the car on jack stands about 18" off the ground. Take off the alternator, plugs, wires and cool packs. It was very tight and I did jack the motor one side at a time but not past the threaded stud. The extra motor clearance allowed them to slide in.
It was harder to get the car up and back in the ground than it was to put the headers in.
I would buy converters to run the rear O2's if you don't have them.
To Kooks Header install difficulty
