C5 chirping underhood
Old Nov 23, 2014 | 03:26 PM
baildvetter000's Avatar
baildvetter000
Default C5 chirping underhood
I have a base 98 C5 A/T with around 95K. Everything runs and works fine till temp. reaches 189 and then a chirping starts under the hood. It fluctuates with engine rpm. I actually sounds like detonation but will fluctuate with rpm even at idle ( no load at all} so I have ruled that out. It also runs just as good ( no knock sensors affecting timing). I have been under the hood with a stethoscope while my wife works the throttle ( damn fly by wire ! ). I have loosened the belt and tried to spin the pulleys that have no load to no avail. I did replace the tensioner as it seemed a little rough but chirping still there. I can keep driving and sometimes the chirping will quit. I am at a loss- anyone else have this problem ?
Old Nov 23, 2014 | 04:56 PM
paoutlaw's Avatar
paoutlaw
I have had that problem with my PU. The belt needed replaced. After replacing the belts the chirping stoped. Sounded like a bird was under my hood. Try the belts if you haven't already. Hope this helps.
The Outlaw
Old Nov 23, 2014 | 08:08 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Same issue i had as well, mine turned out to be AC tensioner pulley. The main belt idler tensioner also is notorious for this. GM made an updated design tensioner.
Old Nov 23, 2014 | 10:31 PM
baildvetter000
Thanks-the A/C was not working anyway so I think I will just cut that belt off and see what happens since cold weather is here anyway.
Old Nov 24, 2014 | 10:35 PM
bad man Barry White's Avatar
bad man Barry White
St. Jude Donor '16
I've heard chirping from three things: belt tensioner, water pump bearing and lastly and the worst a lifter. The stethoscope is your best friend for this diagnosis. The lifter wheel ceases turning and starts to create a tremendous amount of friction on the cam lobe.
Hopefully it's not the last two items.
Old Nov 25, 2014 | 08:28 AM
baildvetter000
The chirping does not start till the temp reaches 189 degrees. I drove and drove the other day and could not get the temp past 185. I had no chirps. Finally I pulled over and idled to 195 and the chirping appeared. I can drive awhile and sometimes the chirping will go away. It sounds exactly like a loud detonation but will do it in neutral so I rule it out. It seems like a heat expansion related noise. I will try the stethoscope on the valve covers and see what happens.
Old Nov 25, 2014 | 09:30 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
MY first thought is going to be the pulleys. You said you replaced the tensioner, but what about the idler? Normally, when one goes out they are all shortly going to fail after that. You should have one idler and one tensioner on the main belt, and the same on the AC side. I would look first at all the pulleys and tensioner and see if you missed one.
Old Nov 25, 2014 | 12:20 PM
wcsinx's Avatar
wcsinx
Detonation does not sound like a chirp.
Old Nov 25, 2014 | 07:13 PM
baildvetter000
Believe me in my lifetime I have owned 8 corvettes, 4 Camaros, 3 impalas, 1 Firebird and 1 chevelle. Five were big block block cars. I definetly know what detonation sounds like. I used the word chirp to get more response. If I had used the word PING everyone would say detonation.
Old Nov 25, 2014 | 09:55 PM
wcsinx's Avatar
wcsinx
I don't know what you're getting at. The 2 sounds are nothing alike. And mis-describing a sound isn't going to get you better results with a diagnosis. Detonation can range from a hollow clunking diesel-like sound to a jarring banging. Now if you're saying it sounds like spun journal bearings which are often the result of detonation then that I can buy. Where is the sound coming from? Top or bottom? That'll give you a big clue.
Old Nov 26, 2014 | 11:07 AM
Jumper11's Avatar
Jumper11
To rule out the water pump, and all the pulleys take the belt off when it begins to chirp. If it stops than you have a better idea where to focus. Because of the heat being generated in the front of the engine, it could be the AC belt, pulley and tensioner. They are separate from the serpentine belt. You can turn your AC on when the chirping starts to see it that changes anything.
Old Nov 26, 2014 | 11:47 AM
Gordy M's Avatar
Gordy M
In addition to the above, you might check the tightness of the tensioner and idler pulleys. I had a similar problem and it involved one of the bolts was getting loose. It started first when the engine was warm and quickly moved to shortly after the start. I was almost ready to replace the water pump when I check the idler pulley.
Old Nov 26, 2014 | 03:01 PM
baildvetter000
When the snow clears and I can get to my garage I will check the idler and pulleys. I have just replaced the balancer ( not for that reason) and as I said before the main tensioner. I drove it yesterday before the snow started for around 15 miles and it never made a sound. That and the fact it only happens after 189 degree temp. really has me stumped. I am going to pull the A/C belt off first and see what happens.
To C5 chirping underhood
