One month with GHL's
Old Aug 3, 2002 | 03:43 PM
ROD BROWN's Avatar
ROD BROWN
Default One month with GHL's
After one month with my new exhaust system,I am really elated.My system has either quieted down or its just my imagination.The mufflers have mellowed down and they really are quite pleasant.I also installed aMagna Flow X-pipe.This may be the reason they toned down.If anyone is considering an exhaust system,you mat want to consider this product.The workmanship is outstanding.The polishing of the stainless steel almost makes it a shame to hide under the car.Thank you,Shawn,and the manufacturers at GHL. :chevy :chevy :flag :chevy :chevy
Old Aug 3, 2002 | 05:56 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default Re: One month with GHL's (ROD BROWN)
ROD BROWN,
You are very welcome! I knew you would like them. Everyone loves the sound!
Shawn
Old Aug 3, 2002 | 08:25 PM
nevadacoin's Avatar
nevadacoin
Default Re: One month with GHL's (L.A.P.D.)
ditto here...they just keep getting better... :seeya
Old Aug 5, 2002 | 01:36 AM
CactusBob's Avatar
CactusBob
Default Re: One month with GHL's (nevadacoin)
Is there any web site for GHL to hear the sound files?? How was the installation ? Thanks - c/b
Old Aug 5, 2002 | 10:53 AM
ROD BROWN's Avatar
ROD BROWN
Default Re: One month with GHL's (CactusBob)
The installation was very easy.The installer removed the stock pipes and installed the entire system in about an hour.My only suggestion is ,cut the muffler clamp ends after the nuts are secured to the clamp.The ends of the clamp potrude quite a long way and drag going into my subterranean parking garage.The tone is great.I vied to install an X-pipe with the muffler installation.just a matter of choice.If you are running a stock exhaust system,you will really hear the difference.I don't know if its my imagination,but it seems I am getting a little better gas mileage.Don't know for sure. :chevy :chevy :flag :chevy :chevy
Old Aug 5, 2002 | 11:04 AM
GHL Exhaust's Avatar
0GHL Exhaust
Former Vendor
Rod,
All of us at GHL thank you for your kind words. Glad you like them.
Brian
Old Aug 5, 2002 | 06:30 PM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
Did the installer have to do any cutting on the stock exhaust to get it off the car? I want to put the GHLs on my '00 A4 coupe, but I also want to keep the stock exhaust parts. I've heard that you have to cut the stock exhaust to get it off the car. :cheers: :cheers:
Old Aug 5, 2002 | 06:33 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Default Re: One month with GHL's (jw38)
jw38,
If the installer takes his time, he can fish out the over the axle pipe so you can have it out in one piece. It may be difficult, but it can be done. After you get the GHLs installed, you are going to want to throw the stock exhaust system in the trash!
Shawn
Old Aug 5, 2002 | 06:40 PM
jw38's Avatar
jw38
Shawn...thanks for the info. Of course you already know that I'll be buying the system from you!!! By the way, I had a feeling you were going to say that about the stock system!!!
:cheers: :cheers:
Old Aug 5, 2002 | 06:45 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
:lol:
Shawn
Old Aug 5, 2002 | 06:53 PM
AP's Avatar
AP
Congrats!
Old Aug 5, 2002 | 08:15 PM
ROD BROWN's Avatar
ROD BROWN
The Istaller DID NOT have to cut the original exhaust at all.He took his time and twisted them right offwith no problem.The old system went into the dumpster.I didn't have any need for them so they were deep sixed.They sure sound great.Even my lady likes the slight roar. :chevy :chevy :flag :chevy :chevy
Old Aug 5, 2002 | 10:08 PM
jschindler's Avatar
jschindler
Thanks for the testimonial. My guess is that you have just gotten used to the sound. I found that to be the case with my PRT's. It is possible that as the get carbon buildup, it could tone down the sound a little.
I'd love to hear a set of GHL's. We need someone in Houston to give them a try.
Old Aug 6, 2002 | 09:18 AM
ProFusion's Avatar
ProFusion
Great results -- sounds like you have a winner.
Is the weight on this system comparable to that of the Borla 140017?
Any pros/cons on X-pipe mod in conjunction with this system?
Is there a Forum GP for this system currently?
Regards
Old Aug 6, 2002 | 10:42 AM
Fahtrim's Avatar
Fahtrim
Default Re: One month with GHL's (ProFusion)
:cheers:
Old Aug 6, 2002 | 11:36 AM
ROD BROWN's Avatar
ROD BROWN
The system is much lighter then stock.I replaced the X-pipe because I heard it makes the tone of an exhaust system more balanced and the X-pipe does away with the "popping".What ever that is. :chevy :chevy :flag :chevy :chevy
Old Aug 6, 2002 | 10:28 PM
nevadacoin's Avatar
nevadacoin
Now I just turn off the cd stacker, because I would rather listen to the GHL's do there thing... :crazy: :crazy: :crazy: :crazy:
To One month with GHL's
