NGK TR55 Plugs
Old Aug 4, 2002 | 03:43 PM
TooManyIDs's Avatar
TooManyIDs
Default NGK TR55 Plugs
Planning to get some of these. Thought I would check in for comments on the benefits (or lack of). Thanks.
Old Aug 4, 2002 | 04:12 PM
Xssesive's Avatar
Xssesive
Default Re: NGK TR55 Plugs (TooManyIDs)
They are good plugs and much cheaper than than the AC's. If you have a 02 Vette I wouldn't think they need to be changed yet. But when they are get the TR 55's and new wires(Magnecor or Taylor), stock ones aren't that good for longevity. :smash:
Old Aug 4, 2002 | 04:18 PM
TooManyIDs's Avatar
TooManyIDs
Default Re: NGK TR55 Plugs (Xssesive)
The reasoning was the colder spark, not wear on the existing plugs.
Can anyone quantify the benefit of a colder spark?
Old Aug 4, 2002 | 09:33 PM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
It's not that the spark is "hotter" or "colder" it's that the plug's "heat range" is hotter or colder. A plug that has a hot heat range transfers heat more slowly to the surrounding cylinder head material. That keeps the spark plug tip hotter and tends to burn off combustion deposits even when the engine is under light load.
A cold heat rang plug is one that transfers head more quickly. They are good at keeping the plug tip at optimal temperature, even, under high load. If they are too cold, however, they can foul under sustained light or no load.
Typically, production engines have fairly hot plugs, such a the 41-974 used in stock LS1s and LS6es or the NGK TR55 or TR55VX. Where stock heat-range plugs can sometimes cause problems is under aggressive driving conditions, such as on a race track. The plug tip gets real hot and can end up a contributor to detonation or, even worse, pre-ignition.
This is why for very aggressive driving situations with engines that do not see starts without warm-ups, I suggest people go one range colder in the heat range.
With the aforementioned NGKs, that would be the TR6.
Old Aug 4, 2002 | 11:02 PM
TooManyIDs's Avatar
TooManyIDs
Default Re: NGK TR55 Plugs (Hib Halverson)
Hib,
Thanks for the thorough explanation.
Based on your post, I assume the NGK TR55's are in the same heat range as the Bosch Platinum's.
Are there other differences between the two? Is it possible the heat range is slightly colder? Would there be any other benefit in changing?
Old Aug 5, 2002 | 01:24 AM
Xssesive's Avatar
Xssesive
Go to http://www.ls1.com/index_faq.html#601 for a break down on plugs and compatiblity. The NGK 55 and the BoschHR9DPX have the same heat range. No they are not colder than stock. You only go to a colder plug with NOS or modifications that require it.
Old Aug 5, 2002 | 01:30 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Al. The stock heat range is 5.
Going up numerically you get colder.
Going down numerically you get hotter.
You want colder for more intense combustion chamber heat, like nitrous, or sustained high rpm.
The TR6's are one step colder, than TR55, but come gapped at 35. Many open the gap some to 40 or 45. You dont want to go much more than that gap, because you will take the electrode out of a good angle.
In General, you gap smaller with more combustion chamber velocity. This keeps the spark from literally blowing out before its time.
There is somewhat of a relationship between smaller gaps and a colder range.
[Modified by kewlbrz, 11:31 PM 8/4/2002]
Old Aug 5, 2002 | 09:54 AM
TooManyIDs's Avatar
TooManyIDs
Great reference. Thanks.
TooManyIDs's Avatar
TooManyIDs
Default Re: NGK TR55 Plugs (kewlbrz)
Thanks kewl.
Old Aug 5, 2002 | 02:04 PM
Mr. C's 5's Avatar
Mr. C's 5
Al,
I put some in before Big Bend. The car seemed to idle smoother and you know I went over 165 without a problem. I'd do it, if I were you. - C.
Old Aug 5, 2002 | 03:03 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In IV Veteran
Cruise-In V Veteran
Shawn, my 02 coupe is prone to detonation, I have been thinking of running the Tr6' at 48 would this be too much gap ?
Old Aug 5, 2002 | 03:43 PM
Xssesive's Avatar
Xssesive
Default Re: NGK TR55 Plugs (Snake Slayer)
Unless you've altered compression or using NOS,you will get the best performance with the stock gap.(According to the Magnecor website) What kind of mods do you have? Are you running stock fan turn on temps? Are you running 93 octane or higher? You should get the best results with the NGK TR 55's at .057 :crazy:
Old Aug 5, 2002 | 04:31 PM
Snake Slayer
Cruise-In V Veteran
I have the NGK Tr55. I just have a constant detonation,
Old Aug 5, 2002 | 04:37 PM
RHILL's Avatar
RHILL
Thanks guys great post :cool:
Old Aug 5, 2002 | 05:11 PM
Xssesive's Avatar
Xssesive
Snake Slayer, did search everyone says it's do most likely to octane of fuel your using, here the thread I read. http://forums.corvetteforum.com/zerothread?id=332933
Old Aug 5, 2002 | 05:24 PM
C5Longhorn's Avatar
C5Longhorn
I have the TR-55's and have had no problems with them. My driving style is aggressive street.
Old Aug 5, 2002 | 09:02 PM
Old Rotor Head's Avatar
Old Rotor Head
Changed at 23K smoother idle no difference in power.
To NGK TR55 Plugs
