I'm just getting back to trying to fix my weird overheating problem. I've been over most everything and found, quite by accident, that the Fan 1 relay has activation power constantly. Even with the key off. There is nothing in my service manuals that addresses this particular occurrence. Or I just couldn't find it in there...
I'm thinking that this is a PCM fault as I can't find a wiring problem. I'm hoping that someone on here has an idea of what might cause this. My next idea is to tear the entire wiring harness apart from the relay to the PCM just to see if there are any bare wires shorting. Otherwise it is time to buy a replacement PCM and hope that it really is the problem.
I've been contemplating just stripping the bitch and parting her out on a street corner. Argh....
lol
4DRUSH is correct. The PCM controls the grounding of the relay coils. If you remove the relays, key on, you should have power on 2 terminals and ground on 1 as long as the engine is cool. The 4th terminal is grounded by the PCM to activate the fans as needed.
Once you have done this you'll know if you have a problem. If you get 2 grounds on any on the relays, unplug the PCM and recheck. If you still have 2 grounds you have a short.
The comment about "bare wires shorting" seemed to indicate The Mountain Kat understands the PCM grounds the relay coil.
But maybe he could elaborate on what he means by activation power because the COOLFAN1 or Relay 45 coil always has power. The coils on Relay 43 and 44 are ignition switched.
Sorry guys for starting this thread and then disappearing. I have been involved in a major remodeling project in my home.
You're correct about this. I found the problem when I was getting exasperated and leaned on the COOLFAN1 relay with my bare arm. It was *hot*. Temperature-wise. I thought that I was being ditzy and left the key on so I looked in and yes the keys were on the console.
I remembered that I had a problem several times, after the overheating problem started, with the fans continuing to run after I turned off the key. I figured that the relay went bad and replaced it. This did not help the overheating but it did stop the run-on problem. Now it seems that the problem that I have now could have been initiated by the bad relay.
Well I got down under Yvette again and pulled the PCM. Sure as hell there was a bent pin touching to the next pin causing a short. I carefully straightened the pin and reassembled things. No more codes and the FAN1 relay is operating correctly. ie; not activated when the key is off. I might get a chance to go for a drive to see if she still over-heats. I expect so as I haven't found any reson yet for the over-heating.
Leave it to my luck that no0one s=else has ever had this problem. Jeez...
