C5 engine trouble - any ideas? (Video attached)
Old Dec 19, 2014 | 04:21 PM
Chris Crawford's Avatar
Chris Crawford
1st Gear
Default C5 engine trouble - any ideas? (Video attached)
My '97 C5 is not well. MAF (Mass Air Flow) sensor was replaced, but engine still not performing 100%. Exhaust putting off a strong gasoline smell. Only error code being displayed is the code for the Intake Manifold Sensor. Could that be the reason for the engine performance/sound?
Shot this video (link below) with sound to show you what the engine sounds like.
Any ideas as to what might be wrong?
What is the clicking sound?
Thanks!
Video link:
Old Dec 19, 2014 | 08:06 PM
Dcollins3208's Avatar
Dcollins3208
What is the code number?
Old Dec 19, 2014 | 08:10 PM
Dcollins3208
Video sounds like a misfire, check your spark plug wires and make sure they are snug on both the coil pack and spark plug. Wouldn't hurt to pull a plug and check its condition either. Hopefully it's as simple as that and isn't a broken valve spring
Old Dec 19, 2014 | 10:30 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Post the codes as already stated above. I agree it sounds like it's misfiring. It should set a code for that.
How is the oil pressure?
Check the balancer for wobble. Then remove both belts and restart it. If it quiet check the accessories, tensionors and idler pullies.
Old Dec 19, 2014 | 11:27 PM
XotiK ZO6's Avatar
XotiK ZO6
That is definitely a misfire of some sort. I am not sure if a fuel pressure issue would cause that issue and not throw codes.
I would check for fuel pressure after checking plug connections as someone suggested.
Old Dec 20, 2014 | 03:20 AM
RedRiderZR1's Avatar
RedRiderZR1
Definitely a missing cylinder. As mentioned look at codes. Should be a P03xx code in there for a missing cylinder. The tick sound sounds like spark arcing.
To C5 engine trouble - any ideas? (Video attached)
