I was outside and just noticed that the bar that goes across the back underneath the car behind the gears that is held on by four nut/bolts is I believe the torsian bar.
There is one nut missing and the other three are 95% off the bolt :eek:
Where can I get another nut and what size is it?
What caused this?
Is there anything I should look out for when I tighten them up?
Sounds like your rear sway bar is about to fall off :yesnod:Who installed the Borla's??? The rear sway bar is typicly removed to remove the stock exhaust...
