Valve cover baffling
Old Aug 5, 2002 | 05:21 PM
Phil97SVT's Avatar
Phil97SVT
Default Valve cover baffling
Is there any way to add some baffling to the valve covers? I would stand to think that adding baffling would reduce/eliminate the problem of oil getting into the PCV valve pipes. Any ideas? I am going to pull the valve covers off and see if I can fab some sheet metal baffles tonight.
Phillip
Old Aug 5, 2002 | 06:01 PM
Blue 02 C5's Avatar
Blue 02 C5
Default Re: Valve cover baffling (Phil97SVT)
Phillip
They already have baffling.
Old Aug 5, 2002 | 08:01 PM
jmX's Avatar
jmX
Default Re: Valve cover baffling (Blue 02 C5)
Old Aug 5, 2002 | 08:10 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Valve cover baffling (jmX)
Hrmm You know I really didnt know that. :rolleyes: I guess the fact that the PCV problem stems from inadequate baffling in the valve covers would lead me to correct this problem. My whole post was to correct the problem within the valve covers not if they had baffling or not.
Phillip
Old Aug 5, 2002 | 08:14 PM
jmX's Avatar
jmX
If you want to fix the issue, get the LS6 valley cover. No need to worry about valve cover baffles any more. I've tried a vacuum pump PCV setup on an LS1 and modified baffles to keep it from sucking too much oil, and it was just a lost cause. If you are serious, do the ls6 valley cover and be happy.
To Valve cover baffling
