Brake pads
Old 12-23-2014, 05:08 PM
CARRJET
CARRJET's Avatar
Default Brake pads
Does it matter with the orientation of the pad wear indicator (squealer tip)?
Old 12-23-2014, 09:35 PM
martysauto
martysauto's Avatar
St. Jude Donor '14
Install the brake pads to the caliper bracket. The brake pad wear sensor, mounted on the inboard brake pad, must be positioned so that it is in the trailing position during forward rotation of the brake rotor.
Old 12-24-2014, 12:22 AM
CARRJET
CARRJET's Avatar
Old 06-15-2020, 07:25 PM
ghurst2135
7th Gear
ghurst2135's Avatar
Which one is the trailing position top or bottom?
Old 06-16-2020, 02:25 PM
CARRJET
CARRJET's Avatar
bottom
Old 06-17-2020, 05:21 PM
GCG
GCG's Avatar
Top:
Old 06-17-2020, 06:37 PM
Tbone1105
Tbone1105's Avatar
Originally Posted by GCG
Top:
this is wrong actually. Trailing end is bottom not top. In the end, it really doesn’t matter. Hopefully your tech will recognize work pads before the squeal will kick in.
Old 06-17-2020, 07:02 PM
GCG
GCG's Avatar
Originally Posted by Tbone1105
this is wrong actually. Trailing end is bottom not top...
Care to elaborate?
The leading edge of a brake pad is the one that may be thought of as first touching the rotor as it turns. If the calipers are mounted behind the wheel axis, the bottom pad edges will lead.
To Brake pads
Quick Reply: Brake pads
