2001 power seat wiring
Old Dec 26, 2014 | 12:11 PM
Dhickok's Avatar
Dhickok
5th Gear
Default 2001 power seat wiring
I just bought a used 2001 and the power seat wiring relay is only partially connected (the previous owner had replaced the seat and didn't reconnect the relay); there are 6 prongs for the 6 wires - 2 yellow, 2 blue, 1 red, and 1 black. Can someone tell me which wire goes to which prong?
Old Dec 27, 2014 | 09:03 AM
dadaroo's Avatar
dadaroo
That is not a stock situation you have. I can provide you with the OEM wiring information but I need to know if you are working on the driver or passenger side and if the car has Memory. Do you need the Lumbar and Bolster wiring also?
Did he install some kind of non C5 seat? If so the wiring info I provide will not apply except for what OEM wiring was left.
Old Dec 27, 2014 | 09:15 AM
Dhickok's Avatar
Dhickok
5th Gear
Default Thanks for the help!
Originally Posted by dadaroo
That is not a stock situation you have. I can provide you with the OEM wiring information but I need to know if you are working on the driver or passenger side and if the car has mory. Do you need the Lumbar and Bolster wiring also?
This is the driver seat which appears original. Yes it has memory but the lumbar and bolster are working. Thanks
Old Dec 27, 2014 | 10:56 AM
dadaroo's Avatar
dadaroo
Ok, I can try and help. PM me with your phone number so we can discuss this and try and get you fixed. Trying to just do this within this Thread will be difficult. We need to discuss several things first. Mr. Sam
To 2001 power seat wiring
