Adjustable end links
Old Jan 2, 2015 | 01:33 AM
rjwz28's Avatar
rjwz28
Default Adjustable end links
Gentlemen,
What's the proper way to set up adjustable sway bar end links? I can't simply measure the factory links as a starting point, since the sway bar is adjustable as well and I will be using the middle setting. The instructions aren't as clear as I'd like. TIA
Old Jan 2, 2015 | 02:14 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Set the sway bar ends parallel to the ground.
Adjust the end links to install.
Bolts should slide in with no interference.
Old Jan 2, 2015 | 02:37 AM
rjwz28's Avatar
rjwz28
That sounds simple enough... thanks!
To Adjustable end links
