HVAC Vacuum line?
Old Jan 4, 2015 | 10:42 AM
Extra260's Avatar
Extra260
Default HVAC Vacuum line?
Working on a neglected 98 C5. Can someone tell me if the vacuum line from the motor goes to the top or bottom fitting on the vacuum cannister check valve?
Mark
Old Jan 4, 2015 | 03:32 PM
zachaeous's Avatar
zachaeous
Default vacuum line diagram
Mark
here is a great diagram of what you are looking for. It goes to the bottom of the check valve.
Old Jan 4, 2015 | 04:49 PM
Extra260's Avatar
Extra260
Default HVAC Vacuum lines
Originally Posted by zachaeous
here is a great diagram of what you are looking for. I goes to the bottom of the check valve.
Thanks for the reply! That helps a ton. I wonder what the other check valve and line goes to?
Old Jan 4, 2015 | 05:03 PM
Extra260's Avatar
Extra260
Oooops! I had scrolled down to see the bottom and now I see it is clearly identified. However My shop manual doesn't show that line. Do the all have them? When I got the car the check valve/valves was missing.
Thanks Again
Mark
Old Jan 5, 2015 | 01:09 AM
LoneStarFRC's Avatar
LoneStarFRC
Here's a picture of just the OE system, without any aftermarket items added.
Vacuum line #13 comes from the engine, and take special note that vacuum line #5, runs either to item #15 OR item #40, depending on which HVAC system (automatic or manual) is installed on the vehicle. Regardless, it runs inside the car to provide vacuum to the control head in the dash.
HTH
To HVAC Vacuum line?
