Comp Cam Trunion Upgrade Questions
Old Jan 12, 2015 | 10:42 AM
Mattie Num Nums's Avatar
Mattie Num Nums
I've been hearing the slightest click clack sound. Happens only sometimes. It's the drivers side. I read that these have a tendancy to un torque themselves. I'm am going to pop the covers and check the torque. What does a bad lifter sound like?
Old Jan 12, 2015 | 10:00 PM
Mattie Num Nums
So I heard the tapping sound again. Pulled the valve cover off and found needle bearings. Used a magnet and pulled a bunch out, turned on the car, took it out for a ride, and it sounds much better!
Sounds like just some left overs from the blown rocker.
Old Jan 12, 2015 | 10:28 PM
StingrayRebel's Avatar
StingrayRebel
I wonder how many more are floating around inside the motor
Old Jan 12, 2015 | 10:32 PM
Mattie Num Nums
I had my tuner change my oil and they found some floating around. I kept all the broken piece and it looks like that should be it. I can put the bearing back together now with the pieces i found give or take a few needle bearings. Im going to change my oil again soon though maybe 500 miles and run some sea foam to clean it out. Its been cold here so I haven't driven enough to get it up to full temp so I am going to take the scenic route to work tomorrow to get a good heat cycle in. I also checked the torque on the bolts and everything is nice and torqued down. I think things are looking up now.
Old Jan 13, 2015 | 08:49 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Does your car have the 2 pc. oil pan? If so, it might be worth dropping the lower portion of the pan, for inspection/cleaning purposes. Just a thought...
Old Jan 13, 2015 | 09:40 AM
Mattie Num Nums
It does not. Just wanted to note the tick is back. I keep hearing about the sewing machine noise being normal but to be honest, we never had a sewing machine so my idea of the sewing machine sound might be a little skewed. Its mostly driver side. Ill pull the driver side cover to just make sure its clean tonight. Can anyone post a video of what "valve train" noise from a dual spring LS1 sounds like? I've looked online and most people are asking the same question as me. Car again feels great!
Old Jan 13, 2015 | 12:21 PM
leadfoot4's Avatar
leadfoot4
There's no reason that your noise, and "running condition" should be fluctuating, UNLESS, as I just thought, some of the loose needle bearings from the OE rockers, got launched in between the valve springs' coils, and are causing the springs to bind. I know it's a long shot, but all I can think of, since I would think the oil draining from the head would sweep the needles to the oil pan, where they'd simply gather.
Old Jan 13, 2015 | 01:24 PM
Mattie Num Nums
I checked it all out looks good. Someone was telling me it just sounds like dual valve springs and that LS1's are noisy. I come from imports so I haven't heard such a loud valve train before.
Old Jan 13, 2015 | 05:28 PM
k24556's Avatar
k24556
the normal lifter preload is .060-.080. Usually, no one will have more than one single push rod length. Now there is a tolerance on valve height, and if you have one valve where all the tolerances stack up and give you the lower end of preload, you may have one valve assembly that is a teeny bit noisier. It may click all the time or just make a little more noise. You posted that you have fixed all your rockers, replacing those of concern.
I think your remaining concern is loose parts from the rocker failures, and it sounds like the loose parts have found their way to the pan, which would be good news. So, you probably aren't too worse off than the rest of us in terms of an eventual failure, so what remains is for you to decide whether it is worth an ulcer to worry. The path to the pan is the ports in the head and down to the pan with few other places for them to go. So, the PP said pull the pan. Good idea. Then pull the intake and valley cover and look around the lifters. After that the only other place for loose parts to hide and later cause a problem is inside the timing chain cover. That one is a really low likelihood, and more trouble than worth the reassurance IMHO.
Old Jan 15, 2015 | 12:52 PM
Mattie Num Nums
The ticking is gone now its just a chugging sound which may be the sewing machine sound. I wish I knew what these things were suppose to sound like, my car is so dang loud everywhere and always sounds like a bucket of bolts :P
Old Jan 15, 2015 | 01:37 PM
leadfoot4's Avatar
leadfoot4
This is just my $0.02 worth.....an LS1's valve train reminds me of some machine I remember hearing in the past, maybe a screw machine, where it makes a cross between a "whirring" sound, and a faint "click", almost like a hydraulic lifter that's 99% lashed correctly, but needs just a hair more pre-load......if you know what I mean.
And if you have headers on your car, that's a different story, as the steel tubing doesn't deaden the exhaust pulses like a cast iron manifold does.
Old Jan 15, 2015 | 01:55 PM
StingrayRebel
did you just buy the car?... if you have had it for awhile and installed the mods yourself then you should be accustomed to what it sounds like by now... it kinda seems like you're paranoid about it and it's getting into your head making you think it's constantly changing or something is wrong when in fact it's normal
Old Jan 16, 2015 | 03:07 PM
  #33
Mattie Num Nums
I've had it a while but I didn't drive it for a while. I am very paranoid because after I installed my mods everyone basically told me it was going to fail and there wasn't anything I could do about it. I drive very easy don't think its been over 3000RPM in 7 months. The 99% lash I totally agree it sounds like that! The only thing that sounds different is there is a chugging sound like a train almost behind the sewing machine. It been cold here too so the car rarely gets to the 180 degree mark in oil temps so that may be the issue too. I am going to try and just drive it and ignore the noise. I have to installed my oil pressure sensor this weekend so ill have the intake off. Anything I should inspect in there for needle bearings etc.
Thanks again everyone for the help and advice.
Old Jan 16, 2015 | 11:00 PM
  #34
RonSSNova's Avatar
RonSSNova
Removing the intake only uncovers the valley cover. It doesn't reveal the engine internals.
