Fluids?
Old Jan 12, 2015 | 06:25 PM
jmacc5's Avatar
jmacc5
Default Fluids?
I purchased a 2002 6 speed triple black vert w/ 6800 on the clock. All original including tires. I have put almost 6k on it since I purchased it in 2012! Love it!!! I have read multiple posts about the need to replace tires(rf vs reg). Still on the fence about which way to go…and when.
I am not sure about the need to have the fluids changed. I do the oil changes and have done the brake fluid.(ranger method). My question is:
How important is it or is it necessary to change radiator, trans, rear and any other fluids I haven't mentioned. And is it a DIY project?
Thanks for any input!
John
Old Jan 12, 2015 | 07:17 PM
corvette77's Avatar
corvette77
I would change those tires ASAP! I went with Hankooks, and have been very happy with them.
I would suggest NOT using the ranger method for brake fluid. I did that once, and it tripped the sensor in the reservior, and had to replace the entire master cylinder. Lucky for me, it was covered under warranty. I now bleed them as you normally would.
However, I do use the ranger method for the clutch fluid, which should probably be done.
I would suggest taking it to a dealership to change the coolant ($100), because if you drain it yourself, not much actually comes out of the radiator. They can hook it up to their machine, which should give it a good flush.
It is an easy DIY job to change the trans and rear fluids too. I went with Amsoil on those. With that low of miles, I would say these two would be a judgement call.
Old Jan 12, 2015 | 07:41 PM
Impulsive goat's Avatar
Impulsive goat
I went with amsoil in my trans and rear as well, there's a vendor on here for amsoil I signed up for the discount, cuts the cost down a good bit.
Old Jan 13, 2015 | 04:28 PM
dtorc4's Avatar
dtorc4
Would you put transmission or differential fluid into your car that had been sitting on a shelf for 13 years?
I didn't think so. Change those fluids. If you have a floor jack and stands or a lift, you can DIY in just a couple of hours.
Old Jan 13, 2015 | 11:54 PM
BigGun's Avatar
BigGun
Yes. Do you see an expiration date on the bottle? Those fluids don't go bad just sitting on the shelf or in the car if not driven. I would just replace the antifreeze. It is recommended every 5 years. I think the dif and trans fluid is good for at least 100k.
Old Jan 14, 2015 | 12:45 PM
Ray 2000 C5 FRC's Avatar
Ray 2000 C5 FRC
You guys missed one other important fluid, the power steering fluid also get changed. Not many people think that is important to change, but on GM cars the power steering fluid gets very hot!!! Just as the differential and transmission fluid.
Enjoy you new toy,
Ray
Old Jan 14, 2015 | 03:56 PM
jmacc5's Avatar
jmacc5
Thx for the reply and advice. However; I misspoke. I meant the clutch fluid, not the brake fluid.
I will probably get it done prior to the "spring launch".
Thanks again, John
Old Jan 14, 2015 | 04:53 PM
bjones7131's Avatar
bjones7131
OM states that the M6 trnsmission does not need to be changed altough I did. Go figure
Old Jan 18, 2015 | 11:31 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks for the mention.
For the OP, I'd recommend the same fluids I use in my 02 Z06 at the track:
AMSOIL Torque-Drive Synthetic Automatic Transmission Fluid (Product Code ATD1G)
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
AMSOIL Hand Pump (Product Code G2039)
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Fluids?
