Replacement tire question.
Old Aug 6, 2002 | 09:48 PM
decay's Avatar
decay
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Replacement tire question.
I know it's posted somewhere here, but I can't find a thread to explain how different tires work. I'm estimating that my GY EMTs will need replacement by the end of the year (merry Christmas!).
1. Can I replace them with non-EMT tires, like Michelins or BFGs?
2. If I do replace them with non-EMTs, will the tire pressure sensors still work correctly (stock wheels)?
3. If I were to get a flat, and used some kind of "flat-fixer-in-a-can" would it kill the sensor?
Based on what I've read about alternative tires better ride and handling, I'm really motivated to go that way, but not if it ends up costing me a fortune in technology replacement--been there, done that.
:confused: :confused:
Old Aug 6, 2002 | 10:16 PM
nevadacoin's Avatar
nevadacoin
Default Re: Replacement tire question. (decay)
yes :yesnod: :yesnod:
maybe :confused:
no :nono:
:cheers:
[Modified by nevadacoin, 2:18 AM 8/7/2002]
Old Aug 6, 2002 | 10:29 PM
BAD2BNE's Avatar
BAD2BNE
I went with the Non-Runflat version of the EMTs..(stock sizes and all) so no fitment problems on stock rims, ride is much smoother, quieter, and better handling all the way around...
Works for me....good luck with your choice...there a lot of them out there that will work for you though..
And BTW, these were considerably cheaper than the EMTs too!!! if you are okay with going without runflat technology..
Old Aug 7, 2002 | 03:59 AM
Richin Chicago's Avatar
Richin Chicago
Take a look at http://www.tirerack.com and the tests on the Bridgestone S03
I replaced my Runflats with these tires and I can tell you everything about them is better, other than they are not runflats. I went to WalMart and got a 12 volt compressor and a tire patch kit. And yes the pressure sensors work fine.
[Modified by Richin Chicago, 2:00 AM 8/7/2002]
To Replacement tire question.
