98 C5 A4 Mod questions
Sarge
1.) Intake 200$
2.)Torque converter and gears 2000$ installed(depends on whether or not you buy,new and/or install yourself)
3) Heads and cam-from 2-4000$ installed
4) headers-1-2000$ installed
You will probably have trouble getting 450rwhp and torque dependably and naturally aspirated on an A4, and if you do you willl need to replace or rebuild the tranny. Look at some of the numbers people here are getting, and you will get an idea of what to expect with heads cam on a driveable A4. Good luck
:cheers: :cheers:
Agree with rrobert22... although with an A4 I'd think 450rw is pushing it a bit. Underdrive pulley and a Blackwing may also help a bit on top of what was suggested. Anywhere between 390 and 420, depending on who's heads/cam package you select is more like it. With an SC installed I'm thinkin it will be a bit over your budget...
My opinion is to do it in the following order:
1) Cold air intake (nice and cheap)
2) Exhaust from Headers on back (2-3000$ installed)
3) Z06 Intake Manifold, air bridge, ported throttle body (about 1-1.5k installed)
4) Then heads/cam (I'd allocate 4000 for this)
5) Gears/TC - 2000-3000
6) After this you'll need a new tranny, Im not sure on cost of that since thats so far away in my timetable, :lol:
Have fun!
[Modified by urslooow, 11:12 PM 8/7/2002]
Good luck & enjoy the car!
