Corvette Newbie Needs Some Advice
I recently bought a 1998 C5 convertible as my mid-life crisis car; my wife and her attorney both agreed it was cheaper than a girlfriend. I need a little advice on getting more power out of my LS1. I had a CTS-V, so the LS6 power was a blast. Now I find myself wanting more power from the Corvette. The car has a Borla exhaust, but it is otherwise stock.
My horsepower target is around 425hp. My budget is around $3500.
After scouring the internet, and finding A LOT OF STUFF, my initial thoughts were as follows:
Blackwing air filter
LS6 243 heads
LS6 intake
Throttle body flow porting
Cam
Valve springs
Decent tune
My car is my fair weather daily driver, so I don't want to turn it into an ultra-cranky, high maintenance girlfriend of a car.
Am I on the right track, or am I in need of serious drug counseling? Any advice is very much appreciated. Please cast thy pearls of wisdom before this Corvette owning swine....
Thanks,
Pete
LS6 243 heads
LS6 intake
Cam
Valve springs
Decent tune
Thanks,
Pete
If you plan on doing a cam there are some parts you should consider changing out since the car is a 98. Oil pump, timing chain, lifters (if doing heads), crank pulley (on a lot of them the rubber wears out and breaks)....You get the idea.
Good advice. Regarding the lifters, be sure to replace the plastic lifter trays with new, unless you decide to use link-bar lifters, in which case you can throw the trays away. Under NO circumstances should used lifter trays be reused. They're cheap, buy new.
HTH
