Quick question on drilled/slotted rotors
Old Aug 7, 2002 | 02:05 PM
swenzi's Avatar
swenzi
Default Quick question on drilled/slotted rotors
This probably sounds pretty dumb, but how do you tell which one is driver side and which one is for the passenger side? Or does it even matter?
To phrase it in another way: when installed, the slot at the top of the rotor should be sloping from rear of the car to the front or vice versa?
Front of car \ Rear
or
Front of car / Rear
I have seen forum member's cars with them installed both ways.
Thanks!
Old Aug 7, 2002 | 02:46 PM
Patches's Avatar
Patches
Default Re: Quick question on drilled/slotted rotors (swenzi)
They are direction-specific. Look at the pic below of my Baer rotor. It still had the sticker on it indicating the side it's mounted on.
Old Aug 7, 2002 | 02:58 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Hmm, good question and answer. I wonder if I would not of even noticed when I install mine this week. :rolleyes: :rolleyes: :rolleyes: :cheers:
Old Aug 7, 2002 | 03:02 PM
fight4yourrights's Avatar
fight4yourrights
Default Re: Quick question on drilled/slotted rotors (racer44)
Nice mirror finish on the actual brakepad! :yesnod:
Old Aug 7, 2002 | 03:04 PM
Patches's Avatar
Patches
Calipers are dedicated to one side as well. So, if you completely dismount them, make sure they go back on with the bleed port on TOP. Probably a good idea to mark them when you first pull them off. :yesnod:
Old Aug 8, 2002 | 09:00 AM
swenzi's Avatar
swenzi
Default Re: Quick question on drilled/slotted rotors (Patches)
Thanks, mine did not come with the nice big stickers.
:cheers:
Old Aug 8, 2002 | 09:57 AM
TooManyIDs's Avatar
TooManyIDs
Chrome backed pads? Doesn't the heat pose a problem?
To Quick question on drilled/slotted rotors
