Help in Brevard County Florida
Old Jan 23, 2015 | 09:02 AM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '07-'09
Default Help in Brevard County Florida
Help!
I have a whine in the left rear that is getting louder every week. I have replaced the wheel brg and did not help.
I think the noise might be the tire. Is there anyone in the Central FL area that would be willing to borrow wheels and tires to fit a C5 just for a hour to see if the noise goes away?
Please...
Old Jan 23, 2015 | 09:21 AM
StngStlkr's Avatar
StngStlkr
I think there are some members in the Southeast forum that live close to you. I would post in there as well to see if someone can help ya out.
If I were closer, I would swing by. Does the whine change with the RPM or vehicle speed? Any codes?
Old Jan 23, 2015 | 09:33 AM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
The Whine goes up and down with the speed of the wheels and tires. Does not change when in N or braking, Etc.
Seems to me like a wheel brg, tire or rear end brg.
Old Jan 23, 2015 | 11:58 AM
randyfl's Avatar
randyfl
PM Sent
Old Jan 23, 2015 | 12:08 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
I would think you could eliminate the tires as the source by raising the rear on a lift, put the car in drive and see if you still have the whine. If you do, then it is probably coming from the wheel bearings or diff. Good luck.
Old Jan 23, 2015 | 12:32 PM
3sACROWD's Avatar
3sACROWD
If the sound seems to be on the left side as stated, rotate your tires from side to side and see if the sound changes location. Many tires aren't directional and even if they are, it won't hurt them for the short period you're testing them.
Old Jan 25, 2015 | 11:47 PM
Forcedvert's Avatar
Forcedvert
If you don't figure it out I would try Bob at the Vette Dr in Melbourne. He is always busy for a reason he knows these cars.
To Help in Brevard County Florida
