Help finding this water leak
Old Jan 24, 2015 | 11:30 AM
1slowride's Avatar
1slowride
Default Help finding this water leak
Hey guys, I am in need of some help to find a water leak. The water is dripping from the area around the starter. Its for sure not a heater core or the heater hoses, it is coming from the motor somewhere. I know there is a water plug above the starter on the block, but it is dry. Also the head and gasket does not appear to be leaking. but over night it will leak a large puddle.
ANY AND ALL input is appreciated.
Mark
Old Jan 24, 2015 | 12:39 PM
LoneStarFRC's Avatar
LoneStarFRC
Mark
The coolant crossover tube under the intake manifold has two small o-ring type gaskets on the ends, one right, one left, at the rear of the engine where they attach to the cylinder heads. They each have one small bolt to secure them. Maybe one is loose or the gasket piece is bad. These small gaskets are available separately if needed.
Old Jan 24, 2015 | 02:52 PM
Dcollins3208's Avatar
Dcollins3208
Check around where the head meets the block on passengers side. Check lower head bolts. And as stated above, the coolant crossover tube as well. If the gaskets aren't sealing, the coolant can run down the block into the starter area, especially if you're parked in a drive way. It might help to start the car and essentially "cause the leak to happen" again
To Help finding this water leak
