How do you drain the rad?
Old Aug 7, 2002 | 06:23 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default How do you drain the rad?
I just got a new 160 stat and TB bypass, I have no clue on how to drain the rad? :rolleyes: Pull the lower hose off? :confused: Thanks! :cheers:
Old Aug 7, 2002 | 06:32 PM
Racer's Avatar
St. Jude Donor '11
Default Re: How do you drain the rad? (racer44)
Is it that funny looking white plug on the lower right? :rolleyes: :D
Old Aug 7, 2002 | 06:57 PM
alanh's Avatar
alanh
That would be it, just turn it and it will come out a little a start to drain.
Old Aug 7, 2002 | 07:00 PM
Xssesive's Avatar
Xssesive
You get a lot of water out of the thermostat housing even after the radiator is drained, found out the hard way! :yesnod:
Old Aug 7, 2002 | 07:06 PM
Racer's Avatar
St. Jude Donor '11
Default Re: How do you drain the rad? (Xssesive)
Thanks guys, as you were replying, I was using that wonderful feature called " search (forgot about that feature) :rolleyes: and all my questions have been answered. Thanks for the tip about the coolant coming out when I remove the stat! :chevy
To How do you drain the rad?
