Need help in diagnosing noise
Old Feb 4, 2015 | 05:10 PM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Default Need help in diagnosing noise
Upon starting and idling,a scraping sound, not a squeel from a pulley or tensioner is heard. The belt turns freely and all seems to be OK. Tried the A/C on defrost and all seems well and no change in the scraping. Need your thoughts and experience. It is so damn cold in the garage so until it warms up a little i'm going nuts as to what could be happening. 99 6mm, all stock 156,000 miles. Well maintained since new .
Any thoughts and/or related information would be most appreciated.
The Big Guy !
Old Feb 4, 2015 | 06:08 PM
jamieo's Avatar
jamieo
Remove the belt and start it.See if the noise is still there.If it is,take a good look at the crank pulley to see if it has separated.Could be rubbing the oil pan or the steering rack.Just a suggestion and a simple test.
Old Feb 5, 2015 | 11:55 AM
The Big Guy
Originally Posted by jamieo
Remove the beltand start it.See if the noise is still there.If it is,take a good look at the crank pulley to see if it has separated.Could be rubbing the oil pan or the steering rack.Just a suggestion and a simple test.
Thank You Jamieo Too cold now, got to wait for warmer temperature
Old Feb 7, 2015 | 06:01 PM
The Big Guy
Removed the accessory belt and found the idler pulley had puked. It was very loud and I swore it was the harmonic balancer rubbing against the oil pan.
Got away cheap this time.
Old Feb 7, 2015 | 08:50 PM
jamieo's Avatar
jamieo
Glad you found the problem!
To Need help in diagnosing noise
