differential bolts
Old Feb 8, 2015 | 02:59 PM
onspeed's Avatar
onspeed
Default differential bolts
Am I correct that the screws that secure the differential mount bracket to the differential should seat fully and there should be no play between the mount bracket and the diff itself? I think I might have mixed up the screws last time I had the rear out. The two top screws that hold the diff to the transmission are the same diameter, although one pair is fully threaded and the other has a grip/partial thread. I'm thinking I swapped the two last time it was apart so the partial threaded ones were holding the mount to the diff and not seating fully.
