Squeaky noise from left rear...
Old Feb 16, 2015 | 05:30 PM
floridacrack3r's Avatar
floridacrack3r
Default Squeaky noise from left rear...
so I have a 99 coupe, I did some search but couldnt find much, anyways recently Ive been getting this squeaky noise coming from the right rear when the suspension is flexing at slow speeds, for example going over speed bumps, I kinda have an idea what it could be, sway bars? shock? what should I be looking for, also the car just hit 90k
Typo in the thread subject, its the right rear, not left.
Old Feb 16, 2015 | 05:58 PM
Gjd's Avatar
Gjd
I had a similar issue with mine.Try removing the swaybar bushings and grease them first before you buy shocks.It only takes a few minute's and worked on mine.
Old Feb 16, 2015 | 06:01 PM
floridacrack3r
Thanks for the reply, Im gonna have to get dirty this weekend and see whats going on down there
Old Feb 16, 2015 | 06:07 PM
k24556's Avatar
k24556
those rubber bushings have a split in them so you can take them off the sway bar. Be sure to clean the sway bar as well, as it may have a rust buildup.
When putting the upper bracket bolt in remember you are going into aluminum. NO impact guns and easy turning all the way, or you may be buying an insert kit (ask me how I know).
Old Feb 16, 2015 | 06:18 PM
floridacrack3r
Thanks for that, I bet I could guess how you know that lol, I've read a few topics that argue putting some silicone on the bushings and some say not to, with the stock bushings is it a good idea to lubricate them?
Old Feb 16, 2015 | 08:18 PM
Gjd's Avatar
Gjd
I used a light coating of wheel bearing grease.Just be sure to wipe off the excess on the outside of the clamp so the road grime doesnt accumulate and cause more problems.
Old Feb 16, 2015 | 09:28 PM
jakecol's Avatar
jakecol
According to the service manual the "Stabilizer shaft Insulator" (Lower) torque is 70 ft.lbs and the upper is 49 ft.lbs.
Old Feb 16, 2015 | 09:40 PM
floridacrack3r
Awesome thanks
Good info!
Old Feb 17, 2015 | 07:39 AM
k24556's Avatar
k24556
I have used silicone on those bushing for a long time no problem, They are neoprene and compatible with silicone grease.
When you go to hard polymer bushings (not needed for street) then regular chassis lube is fine. The polymer bushings need frequent lube or they will fret and open clearances, so I don't suggest going to them unless you have a reason, like turning it to a dedicated track car.
Old Feb 17, 2015 | 07:53 PM
Zealot06's Avatar
Zealot06
Default Could be the shocks…..
Floridacrack3r, mine is a 2002 Z06 with 76K miles.
I have the same sound as you do when driving slowly over irregular surfaces. While looking around for the cause, I found that my rear sway bar was severely corroded and worn. I thought for sure this was the source of the squeak, so I replaced my worn-out sway bar with an Eibach, and replaced factory end links with a set of Moogs. Didn't work.
So I put the car on jackstands and removed both of the rear wheels, and using some bricks and a 2 x 4 for leverage, I moved each rear corner up & down in an attempt to duplicate the sound. I did, and I believe it's coming from my LH shock.
I haven't changed out the shocks yet; still saving up $$, but I'm almost sure that's the cause. If I change the shocks at it's still there, oh well…needed new ones anyway. The search will go on.
Old Feb 17, 2015 | 09:26 PM
floridacrack3r
Yeah I was in the same boat, been looking around for some new shocks and sways anyways. But when I get to looking around at it this weekend I will hopefully find exactly where it's coming from so I know what to replace first
Old Mar 14, 2015 | 12:46 AM
BadMedcn's Avatar
BadMedcn
That sound drove me nuts. Despite checking, loosening and tightening I couldn't seem to locate the damn thing. Finally my son(14) and I went to a mall parking lot after hours and I put him in the trunk of my 01 Vert! Found it! Of all things......the coil over spring had loosened just a smidge, about enough for a sheet of paper to fit. I slight tightening and problem solved. Though yours sound stock, the point is that those suspension components don't need to be real loose to sound like nuts and bolts in the trunk.
Old Apr 10, 2015 | 09:54 AM
BARsC5's Avatar
BARsC5
Is that for both front and rear sway bar mounts?
Old Apr 10, 2015 | 10:42 AM
Joshboody's Avatar
Joshboody
FYI: My leaf spring rubber mounts squeaked... sprayed silicone and gone for now.
Old Apr 13, 2015 | 06:48 AM
linz5's Avatar
linz5
mine was the top shock bushing.. . .I had installed a new set of shocks awhile back and everything was fine until a few weeks ago when I too experienced a very annoying squeak from that area. Replaced that bushing with another one I had left over and fixed for now.
To Squeaky noise from left rear...
