no b/u lights automatic transmission 2002
Old Mar 10, 2015 | 03:23 AM
sargentat44711's Avatar
sargentat44711
Cruising
Default no b/u lights automatic transmission 2002
this car came with a aftermarket T handle made by Hurst and now you can pull the car out of gear w/o pressing brake pedal, if that might have something to do with my Problem , works with Fob, replaced # 38 fuse 12077866 oem# under hood in position # 38 and nothing? Thanks To All That, may be able to HELP ME THANKS MR. MARION WRIGHT or sargentat44711 or sargentat44711@yahoo.com 2002 auto. with T handle shifter ?
Old Mar 10, 2015 | 08:18 AM
dadaroo's Avatar
dadaroo
The reverse lights switch is at the transmission. Probably the switch but first make sure your bulbs are good.
If you want the information on how to jumper the switch to see if the lights works let me know. That would tell you if the switch is the problem or something else.
Old Mar 10, 2015 | 08:29 AM
65GGvert's Avatar
65GGvert
note, automatic
Old Mar 10, 2015 | 09:30 AM
dadaroo's Avatar
dadaroo
Correct. The Park/Neutral Safety switch and the B/U light feed comes from that transmission switch at connector C146. The switch does a couple of other things too.
I would not have known that except worked with a guy on his switch 2 weeks ago as result of a no crank issue.
Old Mar 10, 2015 | 02:35 PM
sargentat44711
Cruising
I have know ideal where con. # 146 is and I replaced the breaker in slot 38 under hood! neutral and reverse switch is in console for a Auto Trans. right?
Old Mar 11, 2015 | 07:06 AM
dadaroo's Avatar
dadaroo
No, like I said, it is at the tranny on the driver side where the shift cable ends. The shift cable activates all the switches there in that one unit.
C146 wiring connector plugs into it. You can unplug it and jumper the reverse switch wires and see if you get B/U lights. Just need the ignition ON (car not running).
I can provide the info to do this if you or a friend want to try.
I just helped a friend replace one a couple of weeks ago. If you want to talk with him let me know.
Old Mar 11, 2015 | 04:15 PM
sargentat44711
Cruising
Default did you notice mine is a automatic transmission?
thanks but, I think the switch you are referring to is in the console w/ neutral start switch? mine is a automatic trans.
Old Mar 11, 2015 | 06:30 PM
LoneStarFRC's Avatar
LoneStarFRC
No!
1. He knows you have an automatic
2. The switch that controls the backup lights is NOT located in the console.
3. I agree with dadaroo as to the likely source of your problem of "no B/U lights"?
Look at NUMBER 1 in this picture, it is the Neutral Safety Switch AND the Backup Light Switch:
Old Mar 11, 2015 | 07:14 PM
65GGvert's Avatar
65GGvert
Originally Posted by LoneStarFRC
No!
Did you check the fuse anytime during the troubleshooting. There's a separate fuse for the b/u lights and the approach lights.
Old Mar 11, 2015 | 07:17 PM
65GGvert's Avatar
65GGvert
Fuse 21
Name:  b-up wiring.jpg
To no b/u lights automatic transmission 2002
