I read that this sealer is recommended for the side cover gasket on the leaking differentials. Any experience using this sealer. Will it weld (glue) the cover in place or will the stuff remain pliable to allow future removals?Some of today's adhesives can really be tough. Appreciate info.
Any possibility of eliminating the "O" ring and making a thin rubber gasket out of gasket material and then using the sealer. Can you skip the o ring.. Doesn't seem to have a purpose any way. The sealer will be the main component here??Will the thickness (match cover thickness) have an affect on the cover and axle shaft.
