where is oil sensor?
Old Aug 11, 2002 | 12:01 PM
CAPTAIN NEMO's Avatar
CAPTAIN NEMO
Default where is oil sensor?
Running 130 lbs. of oil pressure. Time for a new sensor, but where can it be? Need help!
:smash:
Old Aug 11, 2002 | 12:22 PM
C5Noir's Avatar
C5Noir
Default Re: where is oil sensor? (CAPTAIN NEMO)
The oil pressure sending unit is located on the back of the block beside the driver's side head by the back of the intake manifold.
Old Aug 13, 2002 | 01:31 PM
ersatz928's Avatar
ersatz928
Default Re: where is oil sensor? (C5Noir)
The intake manifold needs to be removed to replace the oil pressure sensor.
Old Aug 13, 2002 | 07:24 PM
motoracer's Avatar
motoracer
Default Re: where is oil sensor? (ersatz928)
I have had mine replaced twice in the last year, and they were able to do it with out removing the intake manifold.
Old Aug 14, 2002 | 01:35 PM
non-poster's Avatar
non-poster
Slightly related.. Where is the oil temperature sensor?
Old Aug 14, 2002 | 04:54 PM
ersatz928's Avatar
ersatz928
Default Re: where is oil sensor? (non-poster)
Oil temp sensor is right above the oil filter. Oil level sensor is screwed into the side of the oil pan, passenger side, near the starter.
To where is oil sensor?
