I've searched tons on this and its just not real clear on what fluid to use when changing on the early m6 trans. My 99 frc has 65k miles on it. I hear the early ones have the paper blocking rings and not to run certain fluid. Is there any newer Information that's more clear these days. There's lots of use this,don't runt this going on. Thanks for any help you guys have
I went through this with my 01 and ended up going with what I thought was Dextron lll Valvoline compatable but after feedback from forum i removed it and went with AMSOIL. If I had my time to go over i would go to chevy dealer and get the delco recommended fluid and not wast time and money and U know U have the correct fluid. I have probably 80 bucks in my change.
I have done dozens of cars and several Vettes with amsoil. Everyone of them shifted better especially the Vettes and BMW's. If you go to the website and enter your car it will tell you what you can use. I believe off the top of my head its the red signature series. Good luck in your research and let us know what you did and what you thought of it afterwards.
Chris
I am running Valvoline Dex/Merc which is non synthetic "old" DexIII (what you need) compliant. It works just fine - I have a '98. If you want to go synthetic, you won't typically find one at your local store because the big synthetic manufacturers (Mobil, Valvoline, et al) have all switched to DexVI, which is the current GM auto trans fluid, but per GM a definite no-no in a manual trans.
YUP….19.95 for a gallon of Transmax another $19.99 for 2 qts of Castrol Syntrax gear lube, $9 for GM limited slip additive and $7 for a transfer pump from Harbor freight.
Trans and rear end fluid replacement for < $60.
Use an LS rated 75/90 in the rear end and the limited slip additive is not needed - already in there.
Amsoil synthetic ATF and Amsoil torque drive synthetic ATF are THE ONLY synthetic transmission fluids compatible with the pre-2001 m6 transmissions. It is the only synthetic ATF that has additives to counteract the swelling of cellulose compounds that occurs when they are exposed to synthetic ATF.
The cellulose components are the blocker rings (replaced with carbon fiber in 2001), and if you use anything but traditional petroleum based DexIII ATF or the above listed Amsoil fluids, you are ruining your transmission. Using the wrong fluid is not something you will notice until about a year or two after the fact, and it cannot be reversed without a rebuild.
Amsoil torque drive synthetic is the better of the 2 Amsoil fluids, and is hands down the absolute best fluid you can put in your pre-2001 m6 transmission. Personally, I would still use it in a 2001+ m6 or m12, and many people do.
This is the kind of info I was hoping to find. Thanks everyone for posting.
Sorry missed this point and overcome for the OP as we have traded PMs, but for others reading this thread, this is the best AMSOIL fluid for the T56 and what I've been running in my 02 Z06 at the track for over 10 years now (without failure - though it has been rebuilt twice during that period). AMSOIL Torque-Drive Synthetic Automatic Transmission Fluid (Product Code ATD1G)
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
For what it is worth, I have a 2000 (delivered 15 Dec 1999) C5 with a manual transmission with 65,000 miles on the odometer. I have only used Redline D4 for the transmission fluid for my trans fluid changes which I do about once a year since I do track my car. No issues.
Got the Amsoil today. Swapped the trans and rearend fluids. I can tell a noticable difference in how it shifts. Not that I thought It was bad before. But Id say its worth the time and money.
Not exactly. I have an early '98. Way back when, the dealer swapped the trans fluid for Mobil 1, the old Dex III version. It was fine for years. A while back I noticed the occasional 1-2 balking and grinding into 6th. Refilled with non-syn Dex III, and shifts are back to where they should be - no balking, no grinding, 2 fingers shifts, etc. - this with a shortened shifter. So, no long term damage despite long term synthetic use.
