H/C vs. LPE Super charger -
That is frickin awesome. :eek: :cool: :cheers:
I must have watched that 20 times so far :D. That's all you hear is that supercharger whining! It sounds angry :lol: I like it :D:D:D
[Modified by JD 90 383, 4:30 PM 8/11/2002]
I have been going back and forth on this as well. I have givin' myself till October 1st to figure it out. Now If I could judt do both...... :D :yesnod:
Nick
I understand the physics side of things, but from a practical application that isn't the case.
There are plenty of cars (Supercharged Mustangs) which is where this has been seen a lot.
The move to a better set of cylinder heads actually shows a bigger improvement on a car with a supercharger than on a N/A car.
I am not saying that I have tested this on a LSx platform, but remember, boost is a measure of restriction. Remeber from the GN/TTA days. You could throw a set of ported heads on a car run less boos and make the same power. Turn the boost to the same pressure (PSI) and the car was faster. Why, more air and fuel = more power.
Basically, I'm trying to show that since the S/C mod doesn't have an intercooler, the max boost is ~6psi, going to an overdrive pulley will probably cause detonation probs.
I think since the boost isn't as adjustable as the GN's, the HP gains w/ a H/C mod aren't as noticeable w/ the S/C pkg. Example, if a H/C mod gains ~50 rwhp and a S/C mod gains ~ 100rwhp, the total rwhp gain for both will not equal 150 rwhp. Since both pkgs. cost about the same, I'd take the 100 rwhp first rather than the 50 rwhp.
As usual, dissenting views are always welcome.
Jarrod, let's get together in Webster w/ the women and have a cup of coffee
at Starbuck's some evening. :cheers:
