Lcm5 install
Old Mar 19, 2015 | 11:36 AM
xdmikey's Avatar
xdmikey
Default Lcm5 install
After doing the install and finding I still need to check it due to repeated pull key...occurrences I am finding my remote(new a month or two ago)is dead. Absolutely dead.
I assume this is due to my removing the neg battery cable as instructed in the directions. Should this simple repair step cause my remote to stop functioning?
Thanks.
Old Mar 19, 2015 | 12:10 PM
65GGvert's Avatar
65GGvert
First, near the car, hold down the lock and unlock buttons on the remote at the same time until the horn honks. That will resync the remote to the car. If that fails, enter the DIC fob programming and follow the directions on the display. If you Google "C5 remote programming" you will get video instructions on how if you aren't familiar. This is provided the battery is still good in the fob.
Old Mar 19, 2015 | 06:32 PM
xdmikey's Avatar
xdmikey
Default Thanks guys
Checking my lmc5 install then calling Richard before I lose my work area(wife's part of the garage).
Old Mar 19, 2015 | 10:31 PM
xdmikey's Avatar
xdmikey
Installation was correct. After speaking with Richard we decided at this point my reoccurence was probably due to a weak battery.
He made some suggestions which I will put into play and will keep him informed.
Richard is a pleasure to deal with.
Old Mar 20, 2015 | 09:13 AM
65GGvert's Avatar
65GGvert
Did you try the fob resync yet? Not relearn, but resync as described earlier?
Old Mar 20, 2015 | 11:17 AM
xdmikey's Avatar
xdmikey
Default No sir, not yet
But I hope to possibly this afternoon. Have to have an empty garage or I will be falling over stuff.
Thanks for the help.
Old Mar 20, 2015 | 11:56 AM
xdmikey's Avatar
xdmikey
Default Done
Thanks 65GGvert.
Old Mar 20, 2015 | 02:38 PM
65GGvert's Avatar
65GGvert
Good deal!
To Lcm5 install
