243 heads valve upgrade question
Old Mar 21, 2015 | 01:19 PM
Sinister-one's Avatar
Sinister-one
Default 243 heads valve upgrade question
Can someone tell me what "length" intake and exhaust valves should be ?
Looking to buy 2.08 intake and 1.60 exhaust valves.
Thanks for your help !
Old Mar 23, 2015 | 04:26 AM
RonSSNova's Avatar
RonSSNova
I measured a couple for you.
A bit tough to measure, but I got 4.91" from the flats on the valve face to the tip.
Ron
Old Mar 24, 2015 | 09:57 AM
Sinister-one
Thank you very much Ron !!
Now...... I'm looking to buy a set of:
COMP Cams / RHS Sportsman 2.080" / 1.60" Stainless Stainless Steel Valves.
Will there work for a daily driver ?
Old Mar 25, 2015 | 04:21 AM
RonSSNova's Avatar
RonSSNova
Sure they will. Stock valves are actually a type of stainless.
Just make sure what you are looking at have 8mm stems.
Old Mar 25, 2015 | 11:15 AM
Sinister-one
The description doesn't give stem sizes in mm...
Exhaust valve stem is .3136
Intake valve stem is .3133
To 243 heads valve upgrade question
