Harmonic Balancer Replacement
Old Mar 22, 2015 | 08:38 AM
estefumby's Avatar
estefumby
Default Harmonic Balancer Replacement
I have a 2000 C5 and the balancer is starting to wooble very slightly but I want to have it replaced so it doesnt do any damage. My question is I dont want to replace with GM parts as I would prob end up like this again, any suggestions on what after market part I should use ?
Thanks for the info in advance !!!!!
Old Mar 22, 2015 | 09:33 AM
Chokeu's Avatar
Chokeu
Thinking of doing mine too before it gets out of hand. Here you go:
http://www.summitracing.com/parts/sum-c2501/overview/
Old Mar 22, 2015 | 12:04 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Mar 22, 2015 | 04:46 PM
twizted91gt's Avatar
twizted91gt
I def recommend the Summit racing underdrive harmonic damper if you need to replace your oem one. Its the most affordable underdrive pulley for a C5 and its top notch in quality. You will spend the same $$ on a OEM balancer and get no performance gain. Ive had 3 of these on 3 dif LS motored cars and all of them held up quality wise perfectly. Good investment,,plus you get the added benefit of 2 new belts that are required to install.
Old Mar 22, 2015 | 05:34 PM
rodsvet's Avatar
rodsvet
Just remember that the Summit C2501 is an 8 rib. It works perfectly for a 6 rib setup, you only use the first 6 ribs. I've been running one for 5 years supercharged and pinned as a 6 rib with no complaints. It is not an underdrive. Rod
Old Mar 22, 2015 | 09:08 PM
apex26's Avatar
apex26
I installed a fluidamper sfi approved, which was slightly underdrive, maybe 6% as I recall. No more worries.
To Harmonic Balancer Replacement
