Traction control / ABS light after working on engine
Old Mar 23, 2015 | 04:13 PM
01silvercoupe's Avatar
01silvercoupe
Default Traction control / ABS light after working on engine
So when I completed working on my engine last week, everything starts and runs perfectly except I'm the ABS/active handling light stays on. I'm thinking I left a plug undone. I'm thinking its some plug near the steering box but I have no idea.
I removed the radiator, crank pulley, oil pump, timing chain, heads and everything above them and I moved the steering rack over. In doing all this I must have unplugged something and didn't get it plugged in. Any thoughts?
Old Mar 23, 2015 | 11:43 PM
BigGun's Avatar
BigGun
Use the dic and pull the codes. That will tell you whats not working correctly.
Old Mar 24, 2015 | 11:01 AM
dadaroo's Avatar
dadaroo
I agree pull the codes. The EBCM controls these functions. It is on the driver side at the front. You will know it by all the brake lines. Check the connectors there.
To Traction control / ABS light after working on engine
