Clunking noise
Old Mar 25, 2015 | 04:02 PM
3FloridaVettes's Avatar
3FloridaVettes
7th Gear
Default Clunking noise
I am hearing a clunking noise coming from the back whenever I make a sharp left turn such as a u turn . It never happens when going straight or turning to the right. Any info would be appreciated.
2004 Coupe
Dave
Old Mar 25, 2015 | 06:07 PM
thorvette's Avatar
thorvette
2004 Coupe
Dave
That's the end links. Change to Z06 links and you'll be fine.
Old Mar 25, 2015 | 06:54 PM
cuzracecar's Avatar
cuzracecar
Could.be the famous popping rear axle problem, check out post #32 I believe it is, under the ultimate diy sticky above.
Old Mar 25, 2015 | 08:07 PM
4DRUSH's Avatar
4DRUSH
RR wheel bearing/hub
Old Jul 30, 2015 | 07:01 PM
DavidIvey's Avatar
DavidIvey
2004 Coupe
Dave
Going through the same problem now. Dealer recommended new oil and additive. Warranty company agreed. Now I must drive at least 200 miles and if noise doesn't go away back to the dealer for repairs. What happened to you?
To Clunking noise
