A4 Shifter Cable Replacement
Old Mar 30, 2015 | 12:54 PM
Hussar's Avatar
Hussar
Default A4 Shifter Cable Replacement
I am replacing the shift cable on an 03, The new cable has a red cover over the neutral lock(?) where it attaches to the transmission. This was not on the original shift cable. Is this supposed to be removed after attaching the cable to the transmission shifter arm?
Old Mar 30, 2015 | 01:16 PM
Hussar's Avatar
Hussar
Here is a picture of the transmission end of the cable.
Old Mar 30, 2015 | 02:07 PM
Hussar's Avatar
Hussar
Default Neutral Lock
Are you supposed to put the transmission in neutral, push the bushing on the transmission linkage stud arm and push in the neutral lock? I take it the lock synchronizes the cable to the positions on the shifter?
Old Apr 2, 2015 | 09:08 PM
tbrowne's Avatar
tbrowne
Try this post for instructions:
https://www.corvetteforum.com/forums...o-replace.html
To A4 Shifter Cable Replacement
