Discolored Clutch Fluid
Old Aug 12, 2002 | 02:17 PM
allanlaw's Avatar
allanlaw
Default Discolored Clutch Fluid
Ever wonder what that black crud is in your clutch fluid? Here's what GM has just come out with:
"The fluid in the hydraulic clutch system of 1997-2002 Chevrolet Corvettes may appear discolored. This discoloration is the result of carbon black used in the seal manufacturing process leaching out into the hydraulic fluid used in the clutch system. The discoloration may also collect on the inside of the clutch reservoir at the top of the fluid. This discoloration does not affect the operation of the clutch system and should not be considered a reason to flush the clutch hydraulic system."
Don't know about you, but I sure feel better :eek:
[Modified by allanlaw, 10:17 AM 8/12/2002]
Old Aug 12, 2002 | 02:18 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Discolored Clutch Fluid (allanlaw)
Well I guess that's good to know, I have flushed that stuff I don't know how many times. :crazy: :crazy:
Old Aug 12, 2002 | 03:02 PM
Traffic Hater's Avatar
Traffic Hater
Default Re: Discolored Clutch Fluid (Godspeed)
Thanks for the input. I was just wondering about this over the weekend! I'll leave alone!
Old Aug 13, 2002 | 12:46 AM
MDL-01C5's Avatar
MDL-01C5
Default Re: Discolored Clutch Fluid (Traffic Hater)
I, too, wondered what that stuff was...
:cheers:
Old Aug 13, 2002 | 01:14 PM
luvinc5's Avatar
luvinc5
Default Re: Discolored Clutch Fluid (MDL-01C5)
And all this time I thought the fluid was cooked slowly to get all that crud in it. Anyways, I've flushed and replaced with a synthetic fluid...no more crud.
Old Aug 13, 2002 | 01:20 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
Default Re: Discolored Clutch Fluid (luvinc5)
Did the same - still lots of crap.
Old Aug 13, 2002 | 09:37 PM
MelloYellow's Avatar
MelloYellow
Default Re: Discolored Clutch Fluid (PeterK)
Thanks for the scoop, but also consider the source, bias and motivation.
The last thing GM wants is EVERY 6 Spd coming in for clutch fluid flushing.
My mechanic thinks most likely GM is pulling a :bs move on this one to cover their Azz.
[Modified by MelloYellow, 8:37 PM 8/13/2002]
Old Aug 14, 2002 | 11:00 PM
Pat97Vette's Avatar
Pat97Vette
Old Aug 14, 2002 | 11:14 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Discolored Clutch Fluid (MelloYellow)
GM doesnt care...They dont warranty flushing of fluids...
Old Aug 15, 2002 | 12:42 AM
MelloYellow
Default Re: Discolored Clutch Fluid (C-5 TECH)
Whatcha think the cause is of the whole sticking pedal thing? Just curious. Do you think it's the Slave failing or the Master or the fluid? PP fingers? Replacing the whole assembly every time isn't quite the way I want to go. I've done that 2 or 3 times so far.
This setup with a '02 Z06 Slave, No M/C center restriction, Valvoline SynPower Dot3/4 has worked very well for over a year now. Now she's starting to stick. Happens worse in hot conditions.
The fluid seems to get cooked or go bad over time, eh? The M/C -> Slave line can run very close to the headers, right? Especially people with Long Tube header heat, maybe we are cooking it over time?
Switching to Motul 600 Dot4 & flush and going to wrap my line in Earl's FlameGuard to see if it helps any.
Old Aug 15, 2002 | 01:29 AM
Superj's Avatar
Superj
Man, all this time I thought it was from when I white smoked the clutch. :p:
To Discolored Clutch Fluid
