cooling fans
Old Apr 3, 2015 | 01:49 PM
speedballexpress's Avatar
speedballexpress
Default cooling fans
Anyone know where the heat sensor for the cooling fans is? I can turn them on with a scanner, but that's the only way. Relays and fuses OK. Thanks, Bob
Old Apr 4, 2015 | 12:11 PM
speedballexpress
Originally Posted by 8VETTE7
The PCM turns on the fans. Uses the temp sensor in the drivers side head just behind the alternator for temp sensing.
Here is a wiring diagram that may help:
Have you checked under the battery for possible acid damage to the PCM wiring harness. PCM is located directly below the battery....
Thanks, that's what I needed to know. Bob
