Urgent help
Old Apr 5, 2015 | 06:33 PM
Marine30287's Avatar
Marine30287
3rd Gear
Default Urgent help
Hi guys, I have a c5 2003 manual shift corvette and have backed it outside to wash. I attempted to drive it back in the garage but it keeps shutting off after I pull a few inches ahead. I need to push it back in but when I tried to push it ( I had 3 people help including me) it wouldn't move more than rock back and forth. I had it in neutral and the parking brake off. Does it have some kind of auto brake I need to turn off? Help!
Old Apr 5, 2015 | 07:09 PM
tjschraf's Avatar
tjschraf
Did it say "pull key, wait 10 seconds" or something of that sort on the dash?
Possibly fuel shut off.
Old Apr 5, 2015 | 07:35 PM
Marine30287
3rd Gear
Default thanks
Thanks got though
Old Apr 5, 2015 | 09:52 PM
73Corvette's Avatar
73Corvette
Originally Posted by 8VETTE7
Ahhhhh yes. Yet another manual trans C5 without an LMC5 installed.............
Google "Compliance Parts" and then read about the C5 Column Lock symptoms and the only guaranteed permanent solution........
Keep on preachin brother! Someday the brethren will see the light!
Old Apr 6, 2015 | 11:39 AM
dadaroo's Avatar
dadaroo
I am wondering if a parking brake is stuck. It should be able to be pushed in Neutral.
Jack up the rear and see if you can rotate the rear tires in Neutral.
Could also be a stuck brake pad/caliper somewhere. If the rear tires rotate so the same thing with the front tires in the air.
Old Apr 7, 2015 | 07:26 PM
73Corvette's Avatar
73Corvette
Old Apr 7, 2015 | 10:18 PM
Chicago1's Avatar
Chicago1
I dont think he is talking about that...
OP what codes do you have on the DIC? Possible rotor locked up? Have you started the car?
Old Apr 7, 2015 | 10:20 PM
Marine30287
3rd Gear
Default thanks
Guys I got it u don't have to keep replying on this thread
Old Apr 7, 2015 | 10:23 PM
Chicago1's Avatar
Chicago1
Then share what it was so if others have the same issue they can view this thread and the fix
Old Apr 7, 2015 | 11:21 PM
73Corvette's Avatar
73Corvette
To Urgent help
