Parking brake adjuster question
Old Apr 9, 2015 | 07:10 PM
jodyjo's Avatar
jodyjo
Default Parking brake adjuster question
Trying to adjust parking brakes again and this guy is free wheeling. Did I twist off a bolt or is he just seized up?
Old Apr 9, 2015 | 07:34 PM
jodyjo's Avatar
jodyjo
What I meant was it will NOT TURN with the shoe on. With the shoe off it free wheels and does not adjust.
Old Apr 9, 2015 | 11:51 PM
jim993's Avatar
jim993
If you turn that part over, there is a hole with threads in it that the adjusting bolt screws into. The adjusting bolt has a wide slot in the head that is engaged by one side of the park brake shoe. Unless the threads are stripped it should adjust. Or perhaps the bolt is seized in the part? That would keep it from turning with the shoe on.
Old Apr 11, 2015 | 02:08 PM
lionelhutz's Avatar
lionelhutz
It looks like the adjuster bolt is bottomed in the adjuster. Consider the part with the teeth a big nut and the part with the head that engages the shoe as a bolt. Get a grip on both parts and force them to turn.
To Parking brake adjuster question
