o2sensor plug
Old Apr 10, 2015 | 06:29 AM
maxjett's Avatar
maxjett
Default o2sensor plug
May be a a dumb question but does the left side sensor plug on the right side of car or does left plug in to left side harness
Old Apr 10, 2015 | 09:03 AM
Patches's Avatar
Patches
Front O2's - left --> left and right --> right
Rear O2's - left --> right and right --> left
Old Apr 10, 2015 | 10:26 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
You just really have to watch the sensor wires, since they are angled it is easy to run them to the wrong side.
Not sure what year you have, but on my 2001 the front 02 have a flat 4 wire connector and the rears have a square 4 wire connector.
Old Apr 10, 2015 | 11:29 AM
maxjett's Avatar
maxjett
Pretty sure my fronts are wrong
Old Apr 10, 2015 | 11:52 AM
grantv's Avatar
grantv
That's not good, fix it. The computer will be adjusting for the wrong bank.
Old Apr 10, 2015 | 12:36 PM
maxjett's Avatar
maxjett
Could be why it is running rough at low rpm
Old Apr 10, 2015 | 03:01 PM
grantv's Avatar
grantv
The wires, as they come down into the tunnel area from their respective sides are as noted by Patches.
Re the fronts only; with stock exhaust manifolds it's close and fits great. When you install headers and O2 extensions you need to route the wires keeping them on the same side. Mine essentially went to the opposite side and turn back. As most headers have the bungs facing inwards, it's pretty much the only way.
The post-cat sensors cross over to the opposite side.
To o2sensor plug
