Anti - Venum fix
Old Apr 11, 2015 | 09:25 PM
stainless2007's Avatar
stainless2007
Default Anti - Venum fix
Yesterday I installed a MGW shifter. Because now it has a "notchy" feeling it was suggested to install the washer in the transmission to fix the problem. I searched for an answer but could not find it as to why one thin washer makes a difference. Can anyone answer that?
Old Apr 11, 2015 | 10:35 PM
73Corvette's Avatar
73Corvette
The washer moves the detent bolt out and reduces pressure on the spring... and suppose to make the shifting less notchy... some say it help others see no difference. Some have used two or three washers and then report of a "sloppy" wore out shifter feel... I guess it's just trial and error it's a pretty simple job so it is easily undone if you don't like the results.
Old Apr 12, 2015 | 01:19 AM
janky's Avatar
janky
The detent plug creates an additional pressure which must be overcome by the shifter in order to change gears. The result of this added pressure is a magnifying of the natural notchiness a rod actuated shifter lever normally encounters, so backing off the detent plug a bit reduces that feeling. The plug itself is capped with a spring loaded ball bearing, so small changes in its thread depth create large changes in its preload.
Old Apr 12, 2015 | 12:55 PM
73Corvette's Avatar
73Corvette
Nice explanation...
Old Apr 12, 2015 | 02:04 PM
stainless2007
Thanks for the great answers
Old Apr 12, 2015 | 02:15 PM
blk6spdvert's Avatar
blk6spdvert
Love my MGW shifter. One copper gasket to reduce tension
- then drive it and it will smooth out some more as you shift it.
Old Apr 14, 2015 | 02:21 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I ended with two washers.
Still has the positive feel yet easy to operate
To Anti - Venum fix
