Dash went crazy with alerts
Old Apr 14, 2015 | 03:01 PM
Corvette#2's Avatar
Corvette#2
Default Dash went crazy with alerts
So I was driving my 2000 this morning when all of a sudden the radio shut off. And the dash started chiming alerts. Service engine soon, reduced engine power, low tire pressure.
I pulled over to check the tires. All looked good. Started the car and it seems fine. A block down the road it happens again. Except now my fuel guage reads empty. Get the car home okay and my passenger window won't go up anymore.
Long list of codes. All start with U and end with H.
10 PCM U1626
28 TCS 1301, 1016
40 BCM 1255, 1016, 1096
58 SDM 1301
60 IPC 1255, 1016, 1040, 1064, 1160, 1176,1088
80 Radio 1016, 1064, 1096
99 HVAC 1255, 1064, 1160, 1096
A0 LDCM 2252, 2262, 1064, 1016
A1 RDCM No Comm
A6 SCM 1255, 1300
B0 RFA 1016, 1255, 1064, 1096
I just rolled past 47k miles, owned the car 2 months with no problems until today. I think I'll try a new battery first. The one in there is 4-5 years old.
Does this sound like an EBCM issue ? Weird coincidence the window died. Voltage surge ? Any help is appreciated.
Old Apr 14, 2015 | 03:17 PM
73Corvette's Avatar
73Corvette
Did you check battery voltage? Connections?
Old Apr 14, 2015 | 03:51 PM
Corvette#2's Avatar
Corvette#2
It's been sitting almost an hour. Per my radar detector, the standing voltage is 12.5v
That's a bit low isn't it ? The connections on the battery were tight. Everything looks ok. No leaking or corrosion.
edit, I guess I should get it load tested.
Old Apr 14, 2015 | 04:16 PM
jcgunn's Avatar
jcgunn
Originally Posted by 8VETTE7
Read this thread. It has the makings of being the cause of your symptoms.
http://forums.corvetteforum.com/c5-t...-there-is.html
Bad connection in the connector pictured is the most likely cause....
This is exactly right. You have the symptoms of a bad ground to the BCM.
Old Apr 14, 2015 | 04:23 PM
Corvette#2's Avatar
Corvette#2
Thanks guys. I will read that thread.
Old Apr 14, 2015 | 05:40 PM
Corvette#2's Avatar
Corvette#2
Success!
One of the female receptacles on the passenger door molex connector thing was bad.
I took a small allen wrench and pushed down on it enough so it gets a bite on the pin. Window works again and no codes thrown on my test drive.
I'm lucky to have this forum as a resource.
Old Apr 14, 2015 | 06:45 PM
jim993's Avatar
jim993
Thanks for getting back on the solution.
Old Apr 14, 2015 | 07:52 PM
73Corvette's Avatar
73Corvette
Originally Posted by Corvette#2
Success!
Yup... bad connections. Glad you found it and got it resolved and THANK you for posting your results!
Thanks 8vette7 for the link... I put it in my C5 library.
To Dash went crazy with alerts
