Cooling fans inop
Old Apr 14, 2015 | 09:08 PM
Stevemonacelli's Avatar
Stevemonacelli
3rd Gear
Default Cooling fans inop
The cooling fans in my 1999 are inoperative. Fuse is good. What can I check next?
Old Apr 14, 2015 | 10:17 PM
73Corvette's Avatar
73Corvette
Not sure what you mean by inoperative? When you turn on the A/C do the fans run? What temps are you reaching and the fans not coming on? But here is a link that may help
https://www.corvetteforum.com/forums...icking-on.html
Old Apr 14, 2015 | 10:27 PM
Stevemonacelli
3rd Gear
I am reaching temps over 220. Based on data on the link you sent, should I expect to reach 230 before the fans start?
Old Apr 14, 2015 | 10:29 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well....if you turn the AC on at least one should come on....otherwise they come on as programmed
Old Apr 14, 2015 | 11:01 PM
73Corvette's Avatar
73Corvette
Yes you should expect to see a temp of about 226 before the fans are programmed to come on. That is WITHOUT the A/C on. I think you might even see 230 if the gauges aren't accurate before they come on... 8vette7 correct me if I'm wrong.
If your have the A/C on the fans should come on around 185....
8vette7 asked a great question... which fuse? there are three...
I am still learning MUCH from him... so pay attention when he speaks!
Old Apr 14, 2015 | 11:07 PM
73Corvette's Avatar
73Corvette
Originally Posted by 8VETTE7
If you use the digital display for the temp it usually shows very near 226 when the fans start in low speed mode without the AC running. You might not be looking at the digital display and the temp might be at 230 when you noticed.....
Gotch ya.. thank you
To Cooling fans inop
