Time and difficulty replacing throttle body?
Old Aug 13, 2002 | 07:38 PM
Vinzvette's Avatar
Vinzvette
Default Time and difficulty replacing throttle body?
Im fixing to do this myself and was wondering how hard it is to do. Thanks Vince.
Old Aug 13, 2002 | 07:41 PM
vstella's Avatar
vstella
Default Re: Time and difficulty replacing throttle body? (Vinzvette)
If your generally a handy guy with tools... it's a basic job.:yesnod:
Just don't loose the bolts :lol:
[Modified by vstella, 6:41 PM 8/13/2002]
Old Aug 13, 2002 | 07:42 PM
Bill Reid's Avatar
Bill Reid
Takes about 10 minutes. You'll need a flat blade screwdriver to remove intake duct and a 10mm socket to remove the 3 bolts. Remove the 2 cables and one crank case breather line (from pass valve cover) and slide it right out. Reverse for installation. :)
(edit) oops forgot about coolant. Got the bypass? If not a couple of hefty hemastats or 2 vicegrips to lightly crimp the coolant lines when you remove them from throttle body will reduce coolant spillage to a drop or 2.
:cheers:
[Modified by billreid1@***.net, 5:44 PM 8/13/2002]
Old Aug 13, 2002 | 08:20 PM
potent45acp's Avatar
potent45acp
Piece of cake if you know the difference between a box and open end wrench. Takes 30 minutes max. Be sure to use a torque wrench 12N-m is spec
To Time and difficulty replacing throttle body?
