hydraulic clutch pedal
Old Apr 20, 2015 | 08:31 PM
birchs2001's Avatar
birchs2001
1st Gear
Default hydraulic clutch pedal
The hydraulic clutch pedal on my 2001 c5 6 speed corvette does not maintain pressure and does not allow for the ability to shift / unless I pump the pedal several times - I already tried replacing the clutch fluid several times until the reservoir fluid was clear - what should I try next?
Old Apr 20, 2015 | 08:39 PM
johnson-rod's Avatar
johnson-rod
Sounds more like the clutch master cylinder. Pray it's the master cylinder.
Was there any clutch fluid underneath the bell housing?
Old Apr 20, 2015 | 10:05 PM
k24556's Avatar
k24556
I'd vote Mc as well. The piston seal can rupture and you never get a eak, it bypasses back to the reservoir, so you don't get enough pressure ad flow to fully actuate the slave
To hydraulic clutch pedal
