Best gear ratio for 1/4 mile time in A4?
Old 04-21-2015, 04:27 AM
2001 C5ster
2001 C5ster's Avatar
Default Best gear ratio for 1/4 mile time in A4?
Obviously a shorter ratio will lower your time, but at what point do you end up making your gearing so short that another shift is required to complete the 1/4 mile?
Im assuming most gears will finish in 3rd? I have a 2.73 ratio right now, so will switching to 3.42 still allow me to finish in 3rd?
Old 04-21-2015, 05:40 AM
DRIVER456
DRIVER456's Avatar
Location: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Yes you should finish in 3rd and 3.42's are a good choice.How tall are your rear tires?
Old 04-21-2015, 07:40 PM
84REDCROSSFIRE
84REDCROSSFIRE's Avatar
3.73, 4.11, gears you used to be able to get from the factory back in the day, probably still work today.
Old 04-21-2015, 09:58 PM
4DRUSH
4DRUSH's Avatar
3:42 with 3600 or 3800 TC
Old 04-21-2015, 11:00 PM
JMUSSO
JMUSSO's Avatar
3:73 treating my nicely street/strip
Old 04-21-2015, 11:26 PM
SMT1004
SMT1004's Avatar
I'm in the same boat, ready to upgrade from 2.73. I tried to order RPM Stage II diff with 3.73 couple weeks ago but they had no 3.73 gears and no ETA from mfg. Seriously considering 3.90 vs. 3.42. Even with these gears should remain in 3rd gear unless you start making huge HP. Waiting to order tires so i can alter effective gear ratio slightly if needed.
Old 04-22-2015, 06:54 AM
Rob Petyo
Rob Petyo's Avatar
I run 3:73's but here is a thread about 3:90's
https://www.corvetteforum.com/forums...tall-tire.html
Old 04-22-2015, 04:43 PM
racebum
racebum's Avatar
depends on your hp and expected trap mph along with if you need it to be streetable
use an mph/gear calculator
OR
if it's a street car just rob a rear end from a z06 and enjoy the improvement. don't think i'd want anything deeper than a 342 on a street car even though guys do go 373 and 411, it kills mpg
To Best gear ratio for 1/4 mile time in A4?
Quick Reply: Best gear ratio for 1/4 mile time in A4?
