bearing hub replacement
Old Apr 22, 2015 | 02:42 PM
kennedy759's Avatar
kennedy759
Default bearing hub replacement
getting ready to replace the left front bearing hub on my 97, I have seen one utube video and it shows them removing the tie rod and lower ball joint from the spindle. I can see I need to lower the ball joint bolt about half an inch to have access to the T-55 bolt, but why remove the tie rod end?
Old Apr 23, 2015 | 09:02 AM
Gordy M's Avatar
Gordy M
By removing the tie rod, you have more room to work on the lower Torx bolt. Without removing it you will need to crank the wheel all the way to the right to gain the access. Since the tie rod was very easy to remove and put back in, I did it that way when I replace both bearings last weekend. The spindle will rotate 180 degrees that way.
Old Apr 23, 2015 | 09:27 AM
Cybermind's Avatar
Cybermind
Don't want to hijack the thread but just a quick question:
What hubs did you go with? Timken, SKF, or other?
Old Apr 23, 2015 | 01:41 PM
kennedy759's Avatar
kennedy759
I bought the timken at auto zone $121
To bearing hub replacement
